lgonzalez_1986
dont know **** bout gns
- Dec 12, 2009
interisting i would still go studs<
all that being said why dont you have studs?
Thanks Phoneguy! I use the studs but regret it when the head needed to come off in the car LOL.
I have now gone to studs after lifting my heads AGAIN!! I wont ever be replacing head gaskets while the engine is in the car again, just as easy to pull the engine and my back doesn't get screwed up.
Bryan
That was part of the idea. The other reason is for better instalation of the studs.
Recent ARP brochure showed studs with a allen hex in the top of them to make heads installation and removal in the car maybe possible?
Bryan
How tight are the studs supposed to be screwed into the block?
Install the studs finger tight. This allows the stud to turn slightly when torquing. I put a heavy coat of liquid teflon plumbers putty on all of the studs. I torqued to 60lbs, then 65lbs,then 70lbs, then 75lbs, then 80lbs.Motor is going back in tomorrow. After heat cycling a couple of times I will torque to 90lbs. If I lift another head I am putting the car up for sale!!!:biggrin:
Bryan
just installed my motor had car 3 years had motor out 3 times transmission out 3 times each time I say if I have to take this apart one more time i'm selling it.LOL
