I got my Hallman Boost Controller installed tonight. Few questions before my test drive
1. Do I need to cap off the waste gate solenoid hose fitting ( electric component on valve cover) that the original hose was attached to ?
2. Is the lighter or heavier spring recommend ( current boost is 19-20) ....looking to reach 24-25 if safe on scanmaster. It has the heavier spring installed now.
2.If starting from the closed position, will the HBC add to my current boost of 19-20 lbs or will it start me from 0 lbs and each turn will add boost from there. If from zero, how may turns out ( +) should I use to get a base to start testing.
Thanks for any help
Thanks for any help
