IhaveAcarSickness
- Apr 12, 2012
ok so car had no issues last summer ...pulled her out a few days ago checked and rechecked ...first thing after fresh gas couple hours easy driving and checking everything agin went and got lunch..had a couple millers and left...got on it and the light and it pegged my boost guage at 30 in less then 10 foot ...yikes knock said 5.23 ...oooookkkkk took her home wastegate rod was still on and not moved were i marked it last summer..?took a couple more rides after said and done basiclly the freaking rod has no tension on it and now its back done to 16lbs were i had it and when i say no tension you can take the rod off buy just lifting it up without pulling on it?and 2nd something is draining my battery..pulled all fuses checked relays .radio.heater.fan.fuel pump .even put a new 140 amp alt on it and fresh battery to start cuase i figured batt was bad from sitting and maybe my regulater was sticking....wrong ..what in the hell happened over winter...lol thanks guys
