machinegun
- May 25, 2001
I would agree sounds like a signal loss of some sort somewhere.
Where it is is the issue.
So where are you located? Anyone near you have a scanmaster, direct scan or OTC?
I would ike to know if there are any weird tach readings at the ECM. It seems weird that it all dies but the pump is still running.
Something you could try, get a noid light install at a place you can see. Start the engine and see if when the car dies does the noid stop flashing?
Another item, have you brought the engine speed up some before the engine stops and if so dies it hesitate or just die?
Does it restart immediatly?
One more item, have you checked the ECM socket and Engine wiring harness plug for an loose wires, connections, pins or corrosion?
