I hear ya. Just not sure where I need to be. Been on the back burner for a while. Here is what I have for a setup.
Weber Built TSM Short block – With the following Specifications. This engine has not been fired.
· TSM Legal V6 245ci - Built 2006
· Block .020 Over
· Water Jackets Filled
· Girdled with Stock Caps
· Oiling system modifications per Lonnie Diers
· Comp Cams 236 / 236 Roller Cam
· 110 degree center line on camshaft installation
· 9.16:1 Compression
· .40 thousandths / 3950 head gaskets
· 46cc chamber
· Crank scraper installed and clearanced
· 36.6 Internally Balance
· Crankshaft Key installed / rear crank machined for flex plate
· Oil pan modifications by Lonnie Diers
· Rollmaster Timing Chain 1013-4
· RJC Girdle / Scraper Installed
Additional Components that have been added to the short block, everything listed is brand new unless specifically stated. Most all of this has been bolted to the motor.
· TA Aluminum Heads
· TA Headers – Stainless & Coated – 3 Bolt
· TA Aluminum Valve Covers – Engraved BUICK
· Port Matched Stock Intake
· Port Matched Header Flanges
· T&D 1.65 Roller Rockers
· Accufab Polished Plenum & 70 MM Throttlebody
· Billet Vacuum Block
· Meziere Water Pump
· RJC Pulley Kit
· RJC Airflow Plate
· RJC Deep Sump Oil Pan
· RJC Head Clamps
· Champion Fuel Rails – Stock Location AFRP
· GBodyparts AFPR
· H&R Motormounts
· 200 Amp Alternator
· NOS Tensioner Pulley
· NOS AC Lines
· Powersteering Pump
· Hi Torque Mini Starter
· Caspers XFI Wiring Harness
· Lokar Dipstick Tube
· GBodyparts 3” Downpipe
· GBodyparts Silicone Radiator Hoses
· PTE Stretch Location Stock Intercooler
· Razors AlkyControl Kit
· Racetronix Intake Double Pumper with 2 new Deatschwerks 300 LPH pumps
· Extreme Automatics Stage 3 200R4 w/Brake
· Art Carr 4000 stall non lock-up converter
· H&R Transmission Mount
· Detent Cables For Transmission
· Speedo Cable
· Used 83LB Siemens Injectors
· Used 70 GTQ Turbo
· Complete PowderCoated Engine Bracket Components
