It's a tad more complcated than just having the connector hood. I have the connectors and molds but the connectors are useless by themselves without etching 2 pc boards, soldiering the wires of the correct lengths, then epoxying the pc boards to the inside of the connector hood.
I made probably 50 - 100 maybe more of those wire harnesses. I believe ASC had the tach harness, ground harness, 12v harness, and bulb harness for the 6 guages premade prior to assembling the dashes. The 3 bulbs you see were not a separate harness
It would be very helpful for a clean install the wires the exact color of the ASC originals. The photo I posted above is one of the harness's that I hand made with the correct wire colors as ASC used
I still have a ton of the light bulb harnesses, the ground harness portion, the fuse type light holders and the required resister and the tach harness's but do not wish to let them go at this time.
Joe
