We would like to introduce the TSR class that will be run at the TurboBuick.com Nationals in March. Scot W. is in charge of this class and will be available via email or PM to answer any questions regarding this class. GNS Performance is the sponsor for this and will be paying $500 to win!! Entry fee is $25. Here are the rules:
CLASS DESCRIPTION
Turbo Street Radial is an entry-level Heads-Up class reserved for "Street Driven" vehicles. This class is aimed at the average high-powered streetcar or daily driver, similar to what you would find at the local hangout on a typical weekend evening. Something you can drive 500 miles to an event, Drag race and drive home.
**Amended rule 2/10/2010 :Buick Regal Turbo & TTA Specific class, No Hybrids or SY/TY's
STREET LEGAL REQUIREMENTS:
All cars are required to have working headlights and taillights, Brake lights, turn signals, Heat/air. ALL cars MUST be registered and insured. All race entrants MUST provide such documents during tech.
CHASSIS / SUSPENSION
FRONT SUSPENSION:
All cars must retain factory stock-type suspension. Bolt on aftermarket suspension components allowed. Aftermarket control arms / springs are allowed. Front sway bar MUST remain in place and hooked up!
REAR SUSPENSION:
Suspension components must remain in stock locations. Aftermarket control arms / springs are allowed. Frame rail CAN be notched for tire clearance. MUST have rear sway bar!
FRAME & CHASSIS:
Stock frame rails must be retained in stock locations front and rear.
DRIVE TRAIN
ELECTRONICS:
Aftermarket Progressive Methanol kits and manual boost controllers are PERMITTED. Aftermarket electronic engine management systems are PERMITTED. **Amended Rule 02/11/2010: Electronic / CO2 boost controllers are Permitted
ENGINE:
No cubic inch limits.
Heat / A/C:
Must have all equipment as from factory (Heater box, A/C lines, etc...). Must be in stock location with stock orientation
TURBO:
NO size limit.
INTERCOOLER:
Air-to-Air ONLY, Front mount / stock location Allowed.
EXHAUST:
Must have full exhaust. Must run through that same full exhaust.
No open dumps allowed
HEADS:
Aftermarket cylinder heads, aluminum or cast irons are allowed.
BODY:
The car must retain its original appearance and profiles. Aftermarket fiberglass parts are limited to hoods / trunks and bumpers only.
INTERIOR:
Vehicles must retain the factory interior. Factory door panels, headliner, carpet, dashboard are required.** Amended Rule 01/20/2010: Factory Seat belts OR Safety restraints required
WINDOWS:
Must be of Factory safety glass. No Lexan permitted. All front door windows must be fully Operational.
TIRES:
FRONT: Any front tires permitted with a minimum of 215-tire size.
No Bias Tires! No Retreads!! No Drag Radials!!!
REAR: MUST be Street Radials -- This would be any “Non-Drag Radial” Tire with a tread wear rating minimum of 250. Any width allowed, must maintain 28" height maximum. DRAG RADIALS " NOT ALLOWED "... Regular radial tires ONLY! No Bias Tires! No Retreads!
** Amended Rule 02/10/2010: Tires must have minimum tread depth of 2/32"
RIMS:
All 4 rims MUST match.
Vehicle Weight:
The minimum weight for TSR is 3500 lbs on all vehicles including driver
The GNS Performance TSR class will pay $500 win / $200 RU. This format will be heads-up/pro tree. The RRA for this class will be Scot W. There must be a 5 CAR MINIMUM in order to run the class. Each vehicle entered into the class will be given a GNS Performance license plate that must be on the front of the car before 1st round of qualifying on Friday. I would again like to thank GNS Performance for there sponsorship and continued effort in the Buick Community with new and innovative parts.
CLASS DESCRIPTION
FRONT SUSPENSION:
REAR SUSPENSION:
FRAME & CHASSIS:
DRIVE TRAIN
ELECTRONICS:
ENGINE:
Heat / A/C:
TURBO:
NO size limit.
INTERCOOLER:
EXHAUST:
HEADS:
BODY:
INTERIOR:
WINDOWS:
TIRES:
RIMS:
Vehicle Weight:
