turbo nasty
Turbo Dojo / MNTR
- Jul 19, 2001
A heads up on the kits....several friends have popped their headgaskets from this issue. And while building my new motor I discovered the same.
Issue is the outer 2 studs that are under the valve cover (the mid length ones/2 per bank/4 total per kit) are a little to long.
With the studs screwed all the way in the shoulder of the stud is just under the bolt hole surface so when the gasket crushes and the fastener stretches you are torquing the nut onto the shoulder more than the head.
Adding one washer per bolt will give your the clearance needed for things to work properly.
With thinner headgaskets, heads shaved, etc etc will make this worse even bone stock untouched doesnt give much. RJC, Cometic and FP9441's gaskets have all failed due to this.
Easy check...........screw the stud in and see where the shoulder is ......pretty straight forward there isnt much room at all to allow for strecth and Gasket compression.
Doesnt do much good running studs if you arent getting the clamping force in ever place. And why flirt with disaster
Here are the specs on the washers they come in single, pair or 10 per package. Bought mine from Jegs as they were the cheapest.
Washer - w/o I.D. Chamfer 7/16'' Inside Diameter
13/16'' Outside Diameter .120'' Thickness
