I searched and couldn't find any info on the head bolt kit from ARP #123-3703, purchased from a very reputable vendor....says for 85-87 GN. My problem is that the center two bolts (the longest ones) are too long. They measure 4.5" from the top of the cap to the end of the bolt, and bottom out before the washer is close to the head. I doubled up the washers on those two bolts and it still doesn't feel right, like I'm up against the bolt shoulder and not clamping (little more that finger tight). I had 6 thousandths taken off the head to true it up and I'm using a factory style gasket. Is stacking 3 or 4 washers on this the way to go???
Any help will be greatly appreciated.....Thank You in advance.
