307 when its new is a 190 lph pump
thats about 45gph , x 6.5lb = 292lb hr x .6 bsfc= 486 hp
in a 3600 regal thats about 11.4s
with alky figure you can extend that about 15% or to about 550hp
thats 11.00s @ 123
the 340pump @ 13v when healthy is rated 255lph and can deliver 55gph at 70 psi rail pressure 25psi boost ) thats enough to support 600 hp which will carry a 3600lb regal to around 10.7 127mph
the 60s can flow more than a single 340 can deliver ,
at 100% duty 6inj x 60lb =360lb x .6bsfc = 600 hp, some can run leaner at .55 bsfc so injectors may support 650-700 hp on race gas , or 10.3s @ 132, but you'll need more fuel if you're on a single 340
boost the pump voltage to 15v and keep the boost lower and the 340 can supply more fuel... enough to get close to maxing the 60lb injector ..i would be going to bigger injectors once it went to 80% inj duty
if you spray alky (methanol inj ) others have run the single 340 just into the 9s at 137 + adding about 20% more fuel through the twin alky nozzles , but many have come up short as no two engine combos or cars are the same , your results may vary and become quite costly fast!
if low tens are the goal and you have the rest of the build go with duals like reds double pump XPs or an external ,
