Hey guys,
I had an unexpected expense come up and I need to sell off the 6.0L longblock I was building. I'm trying to gauge any local interest, because I don't really want to ship this - I've done that twice and it's never fun. I'm located in Port St Lucie (1 hour North of West Palm Beach). If you're close enough (within 50 miles) I'll deliver it, any further, we'll have to make some arrangements.
Here are the specs:
00' Iron-headed LQ4 (hot tanked and painted black)
New Clevite rod, and main bearings
New Sealed Power Cam Bearings
ARP rod bolts
ARP Head bolts
Sealed Power Rings
Z06 cam
Z06 pushrods
Z06 springs
GM MLS head gaskets
New intake gaskets
New Valley Cover gasket
New Oil Pan gasket
New Front Cover gasket
My intention was to build a boosted LQ4 with some aftermarket hardware and gasket upgrades with a Z06 cam. The rotating assembly uses the stock components (ie pistons, rods, crank, and heads). Everything else has been changed.
It'll come complete for a drop-in (alternator, powersteering pump, brackets, coils, 2 wiring harnesses, exhaust manifolds (sandblasted/ 2 sets) intake etc...) will be included. The only things not included are the starter and the ECU.
I'm asking $2000.00 or best offer. If I have to ship it, then that will be left to the buyer to arrange. $2000.00 for a BRAND NEW modded motor is a deal of lifetime! Get it before someone else does!
Here are some pics:
MMMMMMM.....Fresh...:drool:
Bottom-End has brand new ARP bolts
New Clevite Main Bearings
New Cam Bearings
New Piston Rings
Fresh Hone on All Bores
Cylinder Heads were hot tanked then bead blasted and clear cloated
Here are the specs:
ARP rod bolts
ARP Head bolts
Sealed Power Rings
Z06 cam
Z06 pushrods
Z06 springs
GM MLS head gaskets
New intake gaskets
New Oil Pan gasket
Here are some pics:
New Cam Bearings
New Piston Rings
