hboost said:Wanna spend less and still get a bad ass intercooler? This ones for you....
GN1 Performance intercooler link
Good up to the 10's!
Ted A. said:It is a complicated answer if you don't let us know what kind of HP you are targeting. What is your buildup?
hboost said:This is true, I've heard of guys having a hard time filling up that RJC megacooler with small turbos....
Then why would it run 160 without the FM?Marc87GN said:There could be alot of reasons for the overheating. Hell, a radiator cap not holding pressure can cause this problem. I have the GN1 front mount with record radiator and stock fan on high and I have never been over 190 degrees. We saw several days at 90-95+ degrees and the car never went over 190 even with the converter not locking. I did replace the hoses, water pump, recorded radiator, cap and have more of a 30/70 mixture since the car is garaged. If it's going over 190 with dual fans, there is something else going on.
Quiky One said:Then why would it run 160 without the FM?
Jason
Um, because when they recored the radiator they used one of those high fin count 4 core cores that can't tolerate any loss of airflow? Just a guess. That cheap $130 F-body radiator really works well with a front mount ...Quiky One said:Then why would it run 160 without the FM?
Jason
Marc87GN said:It just seems odd that the temperature would increase over 30 degrees by just adding a front mount. Are you 100% sure that is absolutely the only thing that changed? You went from a SLIC to a FMIC with no other changes and now the temperature is in the 190s using dual fans?
JDSfastGN said:I believe he is refering to my dads 86 GN. It only runs 190-200 with the AC sitting in traffic or putting around town for a bit in stop and go 35 mph zones with lots of lights(this is 95-100* texas days ). Its fine and runs 175-180 on hot days on the highway with the AC on. It does seem to have a harder time getting rid of heat that is already there, like if i park the car for 10 mins and the temp raises to 210 or so and start it back up, it will take a while to drop past 190 again. Today a front has gone through and im driving the car in 85* weather and its 165-168 and never got above 175 in traffic.... I would recomend dual fans for sure but its not nearly as bad as quiky thinks
