I took my 86 grand national to get the oil changed and the attendant noted that I had a small leak from my oil pan. A few weeks passed, and I got around to taking the car into a auto repair shop that has GM performance expertise & mgmt. to get the oil pan gasket replaced. The shop later called me that day and told me that there were additional leaks, coming from more than just the oil pan gasket. It was just a little bit from the valve cover gaskets and also from the front and rear main seals. I went to the shop and concurred, even though my garage floor was only accumulating a drop or two a week. I didn't want any leaks so I gave them the go-ahead to replace the oil pan gasjet, the rear main seal, the front crank seal and do a full up oil change. I'd already ordered in Eaton posi carriage because I have one of the grand nationals that did not come from the factory with a posi. When I took the car into the shop even though it had high mileage and minor leaks, it ran fine, didn't have any real noticeable problems out of it and all of my Scanmaster numbers were where they should be, no smoke, no noises or knocks.
Today when I called the shop to see what the holdup was on them getting the car ready he told me that during the test drive there was a flattening of a bearing, bearing number five to be exact. They replaced the bearing, took the car back out and it flattened again.
$1250 later I have a new posi upgrade, replaced rear main seal, replaced front crank seal, replaced valve cover gaskets and a full up change, and an engine with a flattened bearing (knock).
I'm so pissed. I don't know if it's dumb luck, nor do I know what to do next other than let them take it apart to investigate the root cause (it was high mileage but running well when I brought it to the shop).
I have 2K-4K to spend but want to spend it right. ALSO, I don't know where liability is.
Nemeses
Nemeses
