REGALTURBO
I Am The Master..Master..
- Apr 20, 2003
Got Razors alky kit installed. Did the tests. Everything seems to be functioning correctly. I have not turned on the alky system yet while driving. I am following the instructions as closely as I can, being very careful and patient trying to get my tune as perfect as I can before using the system.
Since this is a new chip in the car( from my 110 oct race chip to the 93 oct alky chip; TurboTweak). Letting the car learn the chip.
After some driving around and making some initial adjustments at low boost I finally started to lay into the throttle alittle. Noticed the car is taking much longer to boost up. Whereas with the 110octane chip the car spooled up very quickly, it now seems like I have to put the pedal thru the floor and I`m literally counting seconds before it reaches 16-18lbs boost.
I`m just learning the alky system and I want to be very careful but is there a big differance with chips when changing from a 110octane race chip to a 93octane alky chip?
I`m just really noticing some laziness in the time it takes to reached the boost level.
