Fan Hi and Low Fan Relays ,source to buy new relay's?
My 87 GN fan does not come on at right time,car is over heating .
Is there a source to buy new replacement hi and low fan relays that mount on drivers side inner fender ?
If the fans are coming on late it sounds like the intake switch (hi speed fan) is working and the low speed is not.
Are you sure the fan signal from the ecm is working?
have ya pulled relays and checkd connections for corrosion, is integrity of cooling system sound. is the pcm commanding fans on for a reason?
if above all checks out have you checked into control ckt of relay. aka coil side of armature.
