Not sure of this but looks to me like the spring may have been cut already (usually the coils will flatten out at both ends, not just one end). I'd measure the valve (I agree; looks to be 38mm) and get an external WG downpipe (if you don't have it already) and install everything and see where you're at (carefully in case it is a heavier spring than what you want--be ready to let off the accelerator very quickly if needed) before trying to make changes. Install the wastegate without the boost controller first, running a line straight from the compressor housing to the lower port on the wastegate. Leave the upper port open to the atmosphere so you can see what just the spring gives you as far as boost.
