Engine torquing over = knock on shifts?
Toady
I didn't want to hijack SS/GN's thread on the RJC engine brace, so I'm starting a new thread.
http://www.turbobuick.com/forums/general-turbo-buick-tech/299855-rjc-new-engine-grace.html
In the videos showing how much the engine rocks, I was shocked at just how much deflection there was. When people experience "knock on the shifts" - myself included - is this what's happening? And what exactly is happening - stuff hitting the frame as the engine rotates, or the knock sensor going off from the actual movement, or something else entirely?
Just wondering out loud,
It's always possible that's the source but not always likely.
Knock on shifts, particularly the 2-3 shift is most often a result of the load produced at that point. If your tune in on the edge, the added load produced at that shift is usually enough to produce dentonation.
Thanks, Dave. I was going on the assumption that knock on the shifts would typically be false...never thought about it having a real cause like that.
