Engine Help
Boosted Long Roof
HI, All
I'm new to the Hot Air World and I have a 1984 Estate Wagon with 84 Grand National Engine and Drive Train. It has a cracked block and I found a 1979 T Type Regal would like to know if this is the same block or will the intake from the 1984 will fit the 1979 engine. I found that the 1978-1987 engine are supposed to be the same but I know that not to be true.
The internals are the same. Just swap intakes tap the hole for the knock sensor and set it up for fuel injection the heads are the same it will work
yes it is a good start
