Turbo6x2,
What brand water pump our you running? And do you run your car on the street on occasions? Are you running a front mount by chance?
Thanks Jerry
cant really speak for jamie but i think she is running a meziere. i called and talked to gbodyparts, they can get you one no problem. im going to have them get mine soon
I beg to differ. There is no difference in the front covers. Just order it. It will fit and work if you do what we are saying.
you will also need to run a longer belt.
I spoke with GBodyParts, the Meziere unit does not work on the hot air cars. Only for 86-87.
They confirmed what I originally asked here. The alternator belt is in the way. It has nothing to do with the front cover, the pump sticks out too far and the alternator belt would rub on it.
What? I run one and it works fine, have had it on the car for over 8 years and yes I drive it on the street all the time. Not sure why they say you can't run it?
Thanks Jaime !!! That is what i wanted to hear! I am doing a custom twin turbo setup and have a killer mounting plate for the power steering and alt and would love to change out the water pump to something like you are running. Did you go with the HD version or the one with the larger or stronger electric motor? I am not sure if this is an option now but it used to be 5+ years ago when i first looked into using one. Jerry
Wow, way to hijack my thread! Just Kidding :wink:
Any idea what belt you're running around the alt, ps, and crank? Or a measurement if you could? That makes sense as to how it clears, I can understand it better with the picture. What pump is that? The one on gbodyparts says it's a 35gph and not recommended for the turbo model, a 55gph is what they recommend on the turbo model. I can't find a 55gph anywhere though. I was also told by someone that the 96-02 Range Rover pump is the same, any idea if this is true?
