86 turbo t.
Car wouldn't start so I checked the connector plug for the ECU. It had slight corrosion so I sprayed the connector plugs and ECU socket with CRC contact cleaner.
Waited a day for everything to dry, snapped it together and she fired right up, actually ran better than before.
So, I figured a little preventative maintenance was in order.
I pulled the connectors back out and coated everything with di-electric grease.
Snapped the plugs back in and no start again. Even after cleaning all the grease back out it still wont start.
In all cases of no-start, the fuel pump didn't prime when key was turned to run. This got me to the ECU connection idea in the first place.
So i figure the connectors are just tired, maybe lost their tension and not making good contact.
What's the best way to fix this? Can the connectors and wire terminals be replaced? Is there a kit available?
