here is a reply from Megasquirt website....
I'd go with an MS2 running MS2/Extra code; they have a
dedicated LS1 mode that will also work on this engine. Here's a quote
for a solder it yourself kit.
MS230-K $260 Megasquirt-II kit with V3.0 PCB
MK-Boost $7.50 Boost control mod kit
MK-RelayCtrl $5.50 Relay control mod kit
JimStim-K $59 JimStim Stimulator kit
StimPower $8.99 Power supply for JimStim
MSHarness $69 12' wiring harness
EBC_Sol_kit $42 EBC Electronic Boost Control Solenoid Kit
TuneCable $5.50 6' DB9 tuning cable
USB-2920 $22.50 (Only needed if your laptop doesn’t have a true DB9 port)
Subtotal without wideband-- $479.99
I recommend a wideband oxygen sensor if you're tuning it yourself. We
sell the Innovate line.
Wideband Options—
MTX-L digital gauge system $199
LC-1 without gauge $199 (you can still view real-time AFR and datalog
AFR through your laptop)
LC-1 with DB digital gauge $209 (available in red or blue)
LC-1 with G series analog gauge $249
LC-1 with XD-16 digital gauge $299
LM-2 basic data logger with one sensor $349
LM-2 deluxe kit with one O2 sensor $479 (Sale: $399)
LM-2 deluxe kit with two O2 sensors $669 (Sale: $599)
I think this will give you a pretty good start in the right direction.
If you’d like to place an order, you can do so at
Megasquirt Kits / Assembled Engine Management Systems, Wideband o2 Sensor Systems and tuning products - DIYAutoTune.com and it will calculate exact shipping costs
(based on weight of your order) and accept all major credit cards
securely. If there is anything else I can assist with, please just let
me know!
