I spoke with Khai about porting my heads a couple of weeks ago....
I know, that's why I mentioned it...
K.
had that on murphsters head when he tried to push a single pump too far, could stick my pinky in and touch the valve with the head still on the motor ..had it repaired , replaced the warped wiseco piston and he's still going strong
yes , but not just shortblock , its as it came out of box when we picked it up in ohio except the turbo is now a 71hpqbb , ignition is a tr6, a champion alternator only bracket , a dusty ptc converter , no gaskets on the headers , that #1 piston replaced , head repaired , new cometics .. and springs setup by bisonIs Murphster still running my short-block? I remember when he needed a single piston a few years back...
K.
after a spring broke (#5 exh in 2 places) i went to swap in another and discovered that the springs (probably what was sent with heads ) were for a roller but wrong for the billet cam specs he told me the motor had so pulled heads and had bison redo the springs and seals , heads are still unported ,
Absolutely no conclusions yet, as I still have quite a few questions, since I wasn't there when it happened.have to ask... are we concluding that this situation is due to a not perfect gasket seal surface at a repaired spot ?
Did we get to look over the logs and dyno print outs for this yet?Repairable, yes... But they've been repaired in the same area previous already. We'll have to think it over!
K.
thats one way of hurting it.cant believe the tuner would even start adding timing and leaning it out at 20 psiIt alone told me enough that the tuner had no idea what he was doing with this car. Way too much timing, too lean of target AFR,
Check the crank reference angle also. It's wrong on most cars.No, I have not. I'm pretty sure at this point the information will not be passed on to us... The only data I have access to is the very last tune currently in the ecm, which I downloaded to my laptop the other night. It alone told me enough that the tuner had no idea what he was doing with this car. Way too much timing, too lean of target AFR, and a lack of understanding of XFI & the needs of the car...
K.
Oh wow, can you explain in greater detail?Check the crank reference angle also. It's wrong on most cars.
There's a sticky about verifying timingOh wow, can you explain in greater detail?
