boostedturbotom
Miami Dade County
- Jul 26, 2007
derale 16927 they draw high amps but they will out flow any on the market ! bought the caspers plug kit
I also have a PTE front mount and Spals...I have about an inch of clearance between the fan motor and turbo outlet pipe. Keep in mind I'm running an F body radiator which is thinner than a stock radiator, which will give a little more clearance. Also my fans are mounted offset to the left and down so it's not sitting exactly centered on the radiator.
I have not had any cooling problems set up like this. Sitting in traffic on a 90 degree day the temps will not get over 175.
does anyone have pics of a dual SPAL fan setup they did????
thanks!!!
In my opinion, I would not buy Chrysler fans for our buicks. I have the dual 11" Spal fans and those suckers pull. When they kick on, it sounds mean, like a small child would be held up to the radiator. When my temp hits 170*, it goes back down to 160* in like 40 seconds. The mounting is not that hard. I did it. Just used some metal pieces and cut to length. Did buy the Caspers harness too. There is no better fan.
I've read that the fans from a late model F body will fit and work very well. Caspers electronics even has the harness to plug into our cars.
with AC on or OFF ?
AC is gone.
No offense to any vendors, but this is my experience..
I have had 2 sets of the "Ramchargers" fans
1st set pass side motor started to squeal and then died
Next set bought the Caspers harness to fix reason why other set died due to supposed voltage problem well guess what....
2nd set the drivers side fan started squealing and now its dead.
So dont waste your time IMO.
My car gets drove all the time/DD to the max. So a show car/garage queen, strip car the fans would probably last.
DD NO
Im looking at the Spals that Hartline has.
