assume you're talking about dual intank fuel pumps in which case you need to delay (stage) the second pump by using a hobbs switch to turn the second pump on at a point above where fuel pressure with both on is less than the needed fuel pressure ,
typically twin 340s with both running will be at 55psi with stock return lines (yours may be higher)
that means if your base FP is 45 you need to keep the second pump off until you are running over 10psi boost otherwise the fuel pressure will exceed the required pressure ( fuel pressure at 10psi boost will be base 45+10=55psi)
to stage in this case you need at minimum a 10psi hobbs switch (i set mine at 12psi) or higher depending on what your pressure is with both running
or fix your return setup so it can flow back the additional volume when both pumps are on as the stock is not adequate to have both pumps on all the time , typically going to a -6AN return should be sufficient ..you could also use the stock 3/8 feed as the return and upgrade the supply line which i would do if plans are to run power enough for 9 secs full weight car
