I just picked up a set of 3.0 FWD valve covers that I am going to put on my car. Yes, I got 2 "front" covers so each has a hole for the filler cap. Any way, what did those that have these do for breathers? I have seen the set up on John's Performace, the billet adapter and push in breather. I am also looking at having a tube welded into the hole so I can use a clamp on breather. Thoughts? Has anyone seen issues with oil burping out of the cover hole once you give the motor some room to breath? I was leaning toward welding in tubes so that I can get a long run that could help avaid any oil leaking out of the filter.
Also, what did you do with the holes on the ends of the covers. The other benefit to having tubes welded in is that I can have block offs welded in at the same time.
Brent
Brent
