seems like when i start slowing down to s stop sign when it downshifts into first it kind of clunks down into gear, the engine mounts and trans mounts are new, and the u joints arent bad, im thinking there is slop somewhere, the driveshaft has some play if its on the lift in nuetral if i try to turn it, is that normal? like maybe moves an inch clockwise or counter clockwise if i turn it? im gonna pull the diff cover off this weekend to make sure theres not a broken tooth somewhere either, the tv cable is also adjusted the way it should, i dont know if its something interal or not, any ideas?
