1967 GeeTO
- Oct 26, 2003
Recently, I installed a Limit Engineering TA 49, 009 injectors, adjustable fuel pressure regulator and Red Armstrong chip for the 009's and 93 gas. I am experiencing knock per my Casper's knock guage (yellow lights) and Scanmaster (as high as 4.2). The knock occurs even at half or part throttle when the boost gauge gets to around 12-14 pounds of boost. I have increased the fuel pressure in incriments up to 50 pounds and down to 40 with no luck. I dropped it to about 37 and did not have detonation, but the motor would cut in and out. IAC and TPS #'s are in the proper range (20-25 and .40-.42).
For what its worth, I also have Red's fuel pump, ATR Houston style downpipe (no, the puck does not stick), ATR catback exhaust, new turbo "Y" hose and the turbo wastegate hole is port matched to the downpipe. Also, thinking it was bad gas or low tank (about 1/4 full) I filled up with Amoco 93 with no better luck. I have not installed a hot wire kit yet, but will in the near future. Boost should be set around 17 pounds.
I cannot tell you how it was running before because I recently bought the car and the first mod was the ATR downpipe to the stock turbo. As the wastegate hole was not ported, I was experiencing boost creep and could never test the car beforehand.
Any ideas to what the root of my problem is? I'm scared to merge onto the interstate with this situation. Please advise. Thanks, Sam
