Crank interrupter ring
fast400
Does anyone know what the factory position of the interrupter ring is. Mine has the tab edge starting about 1/16" from the keyway and TDC mark....sound right?
I believe it is such as to trigger the crank sensor at 10* btdc I can look later today on a stock one and let you know for sure. sounds about right though.
If you want to be sure it is position on the balancer to spec, I think you can send it to ta performance and they can refurbish it at a cost. Believe I read that on there website a while back but you might want to call them to make sure. Just an FYI.
