onefastcar
mono e mono
- Oct 5, 2005
If you get injector pulse cam sensor is working properly yes or no?
cam sensor was rechecked and it looks good.
if you get rpm indication from stock tach or from scanmaster while cranking crank sensor is good yes or no? i made the crank sensor with a piece of metal and checked ecm connection b5 and i get 12 volts uncovered it is less than a volt is this a good way to check crank sensor?
I still have no frickin SPARK i have been frickin fightin this thing for 2 weeks and i have no burnt wires and have looked at all connectors and they look good fuses are good, i have looked at these schematics till i'm blue in the face and am running out of ideas, i am pulling out the harness tommorrow if no one has something better of an idea for me to head into, oh this is my 4 th ignition module, 2nd coil pack and 2nd crank sensor.
