750H.P.V6
Brutal 6 Racing
- Sep 4, 2001
Guy's,
I wanted to see if anyone other than myself has experienced cracking problems with the newest Champion heads. My first set circa 1998 cracked in the usual places around the bolt holes etc. The "New" version heads circa 2001 turned up cracked just this weekend.
I was under the impression that after 3 different casting revisions that Champion had the bugs worked out, it would appear they don't. Currently BOTH my heads are cracked from the spark plug hole across to the adjacent hole running thru the "racing heads" script machined into the side of the head by Champion.
My initial guess without having checked the thickness in this area is that the castings are thin in the area I've described and that Champion has actually compromised the structural integrity even further by machining stress risers (their name) into the head.
I'm sure if I contact Tom he will tell me he "Hasn't heard of anything like this" that's why I'm posting here to see if others are having similar problem. BTW, the plugs, head gaskets and rod bearings are all perfect.
Thanks in advance for any input.
Neal
Neal
