Goals are mid 10's. Street car that will be driven often.
I have had a set of Champion Iron heads for years. I have all of the other supporting hardware.......
Eagle rotating assembly (stock stroke), DLS 206/206 roller cam (this was for ported iron heads), T&D shafts, 66mm turbo, Precision intercooler, Razor' s alky.
I just got my hands on a set of Champion GN1 aluminum heads with the rockers.
While the engine is apart for freshening my machinist was going to get a set of pistons made to put the piston at 0 deck and adjust the compression with the dish. I was going to set the squish with the head gasket thickness shooting for approx .040". I would like to raise the compression at the same time.
My dilema is do I stick with the iron heads and current camshaft or should I put the combo together with the aluminum heads and get another cam. Is it worth the trouble setting it up for the aluminum heads with a mid 10 second goal?
Lastly........I was going to try to set the compression at 9.1
Would it be beneficial to go higher than this? From what I have seen in the past the aluminum heads can take slightly more. Any info is appreciated.
