turbowidow
- Nov 15, 2003
just thinking out loud here, could you mount an alchy nozzle in the spot where the EGR valve used to go? a plate could be made to hold the nozzle and block the egr port in the intake. could you than use the alky to stem part throttle knock when the egr is removed? this set up would provide easier acsess to nozzle, more stealth apearrance, those mounting MAF sensors in the up pipe could rest easier about alky getting on the sensor, possible better distribution of alky. once again i'm just thinking out loud.
