USMC_Turbo6
- Dec 13, 2009
I am having cooling issues with my car. It tends to run a temp of 205-215 in stop and go traffic. When I am driving on the interstate or long distances the temperature is about 175-183. The car has a 3 row aluminum radiator in it with a shroud that has 2 fans with a casper hotwire kit on them that makes 2800 cfm between the 2 of them. This has been happening randomly for some time now.
1. Have I checked the car to see if there are any water and oil mixing? Yes on numerous occasions and even changed the oil. Everything is clean and fine, no mixing at all.
2. Have I checked to see if oil is in the antifreeze? Yes on numerous occasions and there is no oil in the radiotor at all.
3. Is there any steam coming out of the exhaust? None what so ever.
4. What type of thermostat am I running in my car? 160 degree
5. What type of water combo am I running in the car? Distilled water with 2 bottlles of purple ice and about a quart of radiator fluid for color.
The only thing I can think of next is to put on a new water pump. The current water pump is not that old (maybe 2 yrs old)
Do you guys have any other suggestions to help me figure this out? Thanks
