Trying to solve an air flow problem. I have a thick older intercooler, 12 years old, and a stock radiator. The older twin fan setup on the radiator ( pusher) is not doing the job.
There are fans out there that will flow 6000 cfm from Flex a lite. My question is would it be better to mount the fan as a puller on the Intercooler and the air drawn through the cooler will then pass through the radiator behind it, as it leaves the fan?
Or do I mount the fan as a pusher on the radiator and let the air draw through the cooler, hoping it will suck enough air being a few inches away from the cooler?
I can't mount as a puller on radiator because of twin turbo cooler the pipe to TB is close to radiator.
Third option is use twin old fans on radiator as a pusher and mount puller fan (big unit) on the cooler?
I know its a airflow issue as the faster I drive the hotter it gets.
Any opinions?
Any opinions?
