I am installing a Comp 212/212 Flat tappet cam. I also have a set of valve springs with these specs
Part#68301
O.D. Outer1.27
I.D. Outer0.9
Installed Height1.750
Rate407
TypeSingle
Color CodeNone
DamperYes
Free Length2.020
Wire Diameter0.192
MaterialSilicone
1.75096 lbs
1.700114 lbs
1.650130 lbs
1.600149 lbs
1.550169 lbs
1.500188 lbs
1.450207 lbs
1.400229 lbs
1.350252 lbs
1.300274 lbs
1.250299 lbs
Coil Bind1.1700
My question is how many pounds on the seat should i set them up at?
Part#68301
O.D. Outer1.27
I.D. Outer0.9
Rate407
TypeSingle
Color CodeNone
DamperYes
Free Length2.020
Wire Diameter0.192
MaterialSilicone
1.75096 lbs
1.700114 lbs
1.650130 lbs
1.600149 lbs
1.550169 lbs
1.500188 lbs
1.450207 lbs
1.400229 lbs
1.350252 lbs
1.300274 lbs
1.250299 lbs
Coil Bind1.1700
