Pulled the motor over the winter due to a blown stock head gasket on #2 cylinder. Decided to add a roller cam and ported heads. I must have talked to a dozen people on head gasket advice and finally settled on Cometic.
I was warned to use copper spray on the outside and in between the layers which i did including new APR bolts.
I now have a leak on #3 cylinder between the layers. Retouqued the heads and had no effect on the leak. Did i improperly prep the gaskets? The only thing i didn't do was heat the cylinder heads and block when i initially torqued the heads. Talked to Julio and went 20, 40, 60, 85 on the torque for the bolts.
The toon is good with zero knock at 25 pounds on Alky. I guess something must have been off. I'll know more when the motor comes back out.
Any advice on head gasket choice would be greatly appreciated.
Thanks.
Thanks.
