TurboGN,
I also did my rods and mains in the car, such fun..., when it looked like a little too much crap from my dieing timing chain went thru the bearings. I ordered Clevite77 bearings from Autozone. My GN had one half of the factory main shells stamped .001 and the other half not stamped with anything, was yours like this? I'm assuming both my upper and lower bearings were .001 as when putting a mic on them thickness w/in 0.0005 but my mic is only accurate to 0.001 so I'm still not sure if the non stamped factory bearing was std or .001. So I put .001's back in and when checking w/ plastigauge things showed tight around .0012 to .0015 on the mains but figured that would open up a little once they scuffed in slightly. So again, I'm assuming both stock bearing shells were .001 as this seems like a decent factory clearence setting. I've heard stories about the factory mixing bearing sizes to get whatever clearence they were looking for on the assembly line.
