hi to all out there I need some help with a small problem. ihave a knock gauge which is installed in my 87 turbo t. the problem is the gauge is not working properly. It's a 3 wire hookup 1 power 2 ground and 3 to the yellow/black off the ecm. I did this as per instructions and the light goes green when the ingition is turned on then goes into the red when cranking and stays there. I have the power plugged into the ignition port in the fuse box. I tried for the hell of it to go into a bat port and the gauge seemed to work fine, problem is it wont shut off that way. I also noticed that before wiring it for the 3rd time today, when the gauge was hooked up ( all 3 wires) it would affect my knock reading on my scanmaster, meaning my scanmaster knock would not work! I unplugged the gauge for the time being until I can find the problem, Any suggestions??? thanks all....
