Yes custom pipes have to be made.I may have intercooler modified to point to side then get 90* hoses to go through hole already in core support I may end up about $300 on whole deal. IMO its way cheaper and just as good
Can someone post pics of the area behind core support where pipes meet ic. There's a bracket that seems like it may get in the way. Its the bracket from core support to inner fender well... Thanks
Yikes I got the holes cut went to slide header panel on... Oh no won't fit. Its wider than the whole inside of the grille I had to cut into headlight bucket all the way past the headlight adjuster screw on one side other side I did a lil less.
Had to shave header panel down where headlight buckets go one side past adjuster screw other right to the screw. Replacing core support bushings so I took the support out till I get them. More to come
