REGALTURBO
I Am The Master..Master..
- Apr 20, 2003
I`ve done some searches on this and even explained this in a prior thread. Just looking to see if anyone has any opinions, ideas or answers. I`m still in the tuning process of my alky system. Razors system. Looking for that sweet spot where I have the max boost level, right amount of alky and no knock. I feel as though I`m close. My runs with the control knob at 6 show 0.5 deg retarded on my scan master at most. I want zero. Car is still alittle rich. Looking to trim more fuel and maybe retard some timing. All at 23lbs boost so far. But my goal is 25lbs boost.
This is what I`m experiencing....whenever I make a run with the car, whether it be a short 1/2 run light to light or an all out 1/4 mile run the car runs very rough immediately after. 02`s drop down to 038, 046, 053 then slowly climb back up to normal numbers at idiol. BL numbers - 128. Int - 128. Runs like some plugs are fouled for 5 minutes or so then clears out and runs normal again.
Any ideas what is going on or what I can check?
