usetaboost
SAY CAR RAMROD!!
- May 4, 2005
Like I said, there' could be a 1-2lb variance to these numbers, but it varifies that fuel psi is going up and holding consistently.
kidglok said:maybe its too rich, never did trust a narrowband
Damn near two years later the car still runs the same on the same setting. 11.0 at top of third with wot fuel maxed out, saw 1.2 kr at the very top of third. Car shifts around 52-5300 rpm. I find it hard to believe the car makes enough power to run injectors near max but the car pulls like a freight train through the entire pull. Did this three times back to back. Bob and I have ruled out the fuel pump. No leaks of any kind.
When I add fuel to it the o2s come up and wb goes down. If I left the settings default on the chip it would probably kill itself
Yep, yep ,yep and yepAlright, I thought on it. I drank on it. I slept on it. I'd start looking at your injector harness. Injectors can't do what the ecm tells them to do, you will go lean even with perfect fuel pressure. I'd bet you got a corroded pin somewhere at a connector or you got a power feed problem to it. I could easily be wrong but I think the ecm toggles the ground and the injectors have a costant positive connection. Could also be a rogue injector doing weird sh!t leaning out one cylinder. If you had a marginal injector harness connection somewhere, the first time it's gonna show itself is when you are really leaning on it. AND it would probably be different every time you got on it...
A powerlogger would REALLY help eliminate some variables here.
