I got the GN back this week from getting the transmission rebuilt, I ordered parts from CK Performance.
The car runs great from a roll or kick down, I can chirp the tires from first to second gear easily, sometimes at half throttle. However, I cannot powerbrake this car. It's not that I don't know how, I've done a few before in this car. No matter how much gas I give it and let off the brake I cannot get this car to do a burnout. It just kinda sputters and then takes off hard once the turbo kicks in. From a dead stop, no powerbraking, it will roll forward and slowly climb to 15 MPH then all of a sudden just take off. The car sounds like it's missing out, sometimes at idle, sometimes at speed. Do any of you know what this could be? The only thing I've tried so far is switch out the coil pack with a buddy who has a turbo regal, but that didn't make a difference.
My mods are: 42lb. injectors, turbo tweak chip, K&N cone filter, magnaflow mufflers (no cats), and the rebuild transmission with new stall converter.
The Scanmaster readings were taken after driving the car and getting it up to temperature, the car was in park:
085 0.0
AF 07
L8 37
BAT 12.8
Int 128
bL 126
nPH 00
Clt 189
AtS 109
r 900
tPS .46
IAC 37
NAL 00
When I hold down the recall button I get a: 746 0.0
When I hold both buttons down I get a: 23.000
Any help would be greatly appreciated, thanks.
085 0.0
AF 07
L8 37
BAT 12.8
Int 128
bL 126
nPH 00
Clt 189
AtS 109
r 900
tPS .46
IAC 37
NAL 00
