Braxton Jordt
- Mar 18, 2013
Set up is, ta 49 turbo, powerstroke front mount, PTC converter, walbro 340 fuel pump, hot wire kit, power plate, 42lb injectors, previous owner said it has a 208 cam?, boost controller at 23 pounds, alky kit.
Fastest I've been able to run my car is a 13.4 with a 1.8 60ft. This car just falls on its face at the top end. It's got a loud tick on driver side engine it sounds like. No cracked header. Could this be a flattened cam? Maybe needs new valve springs? The car runs great no stuttering or hesitation and has good compression. Any ideas would help thanks in advance
