There is alot of differences between the 4T60E and the 4T65E-HD(SC cars). The 4T65E-HD has a much beefier differential and other parts. The 4T65E(non-HD used on non-SC cars), has the same differential as the 4T60E, but does have the same clutches and related parts as the 4T65E-HD. Ask someone who has worked on both, there is a big difference in terms of strength. INTENSE has a turbo car running about 650hp though a modified 4T65E-HD, and GM has 750+hp Ecotec running a modified 4T65E-HD.
Also I was refering to the Series II block, not the older Supercharged model. There is little to no difference in the Supercharged block compared to the non-SC block. But the Series II has crossbolted mains and other advantages. I would doubt the older 3800 block is any stronger than the RWD block. There is a car running 500hp on an almost stock Series II short block, and one running 650hp on a stock block, crank and rods.
-T
