I did my normal routine of starting up the car to have it run for a moment. I have done this a couple of times using my remote start to keep it loose. Well tonight I popped the hood on my buick and the fan wires were burnt. So I turn off the car... which by the way was when the fan kicked on. (the car had not reached temp for it to turn on). When I touched the wires they were HOT! So i pull off the jump wire, the one to circumvent the resistor, and it kept running. I go to disconnect the harnes and its basically melted together. Any ideas? Can I disconnect the big fan relay (the one that tells the fan to run after I shut off)?
Has this happened to anyone?
