carl creque
- Jun 25, 2003
There is what appears to be a nice C06 Skyhawk on the Portland Craig list right now.
Always have liked the little H-Body cars, especially the Buicks! Those builds will be awesome when you guys get done!
My car is done,we'll it's never done.
Mine is still in surgery. :frown:
Su 09 Nov 2008My car is done,we'll it's never done.
Dear Carl:
As the owner of an '83 El Camino [me, a decades-long Ford enthusiast], I decided to 1st update my ailing Turbo 350 C transmission [lock-up converter], with a conversion to a 200-R4; then to LATER drop-in a late model truck 350 [4 bolt mains]. This, Carl is how I discovered you, via this forum (PS YOUR car is PHAT!)
I would prefer the engine choice to have been a late model LS series engine, or even a 3.8 Buick GN engine, but, the sensibility of such a large $ investment in this PARTICULAR El Camino, is questionable. [eg: '83's are valued at only +/- $10 k in #1 restored condition, while a '70 / '71 similar model is worth $29.5 k! duh...]
Why I joined this forum is to share my journey with the modifications to / installation of the 200- R4. I am sorting-out all the mods / cost to bullet-proof that conversion [car is daily driver], and ask people like you to share discoveries you have made. Most importantly, though, my LACK of "working" knowledge" of the GN Turbo Buick Engine.
My brief background encapsules being a Buick line mechanic in '68 / '69; later, working w/ the late funny car racer, Malcolm Durham several times over the past 40 years; building many outrageous "street" hot rods [notably, the '64 Falcon w/ 428 FE engine, straight axle, 9" rear, C-6 transmission which was my then '68-'69 daily driver *the axle was 'cuz we didn't have strut front ends back then. The technology was NOT available to hot rodders until much later]; am an [expired certificates]: ASE Master Truck and Auto Mechanic; ASE Master Machinist: currently working as a mechanic w/ USPS Vehicle Maintenace [boring!!]; and frustrated driving the 140 Hp, high mileage 305 El - which is a nice car, but horribly........un-exciting.
Questions you might know are: Which 3.8 BLOCK-CRANK configuration [odd fire vs even fire] is the best to build; and WHY is that so?
Where can I get that at a reasonable cost?
What is the Hp capabilities of this engine under HIGH boost as compared to overall cost to achieve that level of power? [likely would use Snow water / methanol injection to deal w/ detonation issues]
How stable would such a package be - ie: would it be durable, or a virtual 'hand grenade'?
Anyway, I hope I haven't taxed-you to much w/ my initial questions. Maybe someone else in this forum will also offer their knowledge and experience.
FYI: I compliment you on your apparent (photos) workmanship, and choice of cars. What rear axle are you runnig? What about traction and 'hooking' it up to not be just a tire-burner? It should fly!!!
Thank you for any suggestions, or references to other sources of reliable data.
Peace, Amir.
Su 09 Nov 2008
Dear Carl:
Peace, Amir.
Hi, Amir. Thanks for the compliment on my car, but it is a little mis-directed. The only credit I can really take for it is the idea to do it. I also only know what I have read and researched about the GN drivetrains. Scott (UR50SLO) on the board here is doing the conversion on my car. He also built the engine for it. Obviously he is a very talented individual. Real stand up guy, too.
I will attempt to answer some of your questions with my limited knowledge. All of the GN engines were odd fire. The stock block of choice is called a 109 block. 109 is the last 3 digits of the block casting number. There are also aftermarket blocks that are stronger up to the all aluminum TA Performance block (capable of handling 2000 horsepower!). For the rest of your questions about durability and cost, I suggest you talk to one of the various vendors. Others on the board here will chime in with who they are I am sure.
Right now the rear end in my Skyhawk is a stock 7.5. It is very similar to the rear end in your El Camino. I have a few parts to beef it up and I hope that it lasts a while. The Skyhawk has a torque arm suspension from the factory which is similar to the later Camaros/Firebirds. It works fairly well in stock form. Scott has installed subframe connectors and beefed up weak areas of the car quite a bit. I hope that it doesn't blow the tires off when he gets it up and running. One good thing about the turbo cars is that the power comes on smoothly and doesn't shock the suspension too much.
Hope I was able to help some. I am sure others with much more knowledge than me will jump in to help you.
Carl,i sent you a PM.
Thank you Carl...
