bracket for alchy bottle and rc dual fans and front mount ic
I had a nice solution, if you run the stock ic.
Not sure if I got a pic. No i dont. Well heres what I did prior to engine removal for rebuild.
I use a piece of sheet metal and laid it on top of my IC, used the exsisting screw holes to attach plate to IC. I then set botlle on ledge, and used the zip tie attaching it to the center of the fan set up. So the botlle was directly between the two fans, the ledge held 90% of the wieght, while the zip ties held it from falling. Hood would close fine, and much easier to fill. I may even have the piece of sheet metal here, id have to look. If i do, and you want it, let me know. Just pay the postage and I'll send it, If i have.
DAve
Dave
I have a eastern front mount I tried a metal strap type also it was no prettier than my ugly license plate holder....thanks for that tip though
Alan
I assume you have a bottle for the alky that you dont know where to install it and its a SMC kit?
Call steve and see how much it would be to upgrade to the new GM overflow bottle and external pump.
I did just that, now i dont have to worry about where to install the bottle.
BW
