turbojimmy
Supporting Member
- May 26, 2001
Greetings all......
MY turbo puts out way more air than the engine can use. Before I moved to this T70, I would only get 'the flutter' when I closed the throttle, which is fine. But now when trying to accelerate at a hard, steady pace at like half throttle there's more air hitting the throttle plate than can go through and it flutters. I can't accelerate smoothly unless I go WOT or really light. It makes all kinds of fluttering sounds and the boost gauge jumps all over the place. It gets a lot of attention, but I think probably because it sounds bad. Would a BOV solve this problem even at part throttle? I would imagine it would since it's acting on the difference in pressure between the intake and the pressurized side of the turbo? Is there any other way to address this (other than a smaller turbo)?
Thanks,
Jim
Thanks,
Jim
