i have been have problems getting my boost down to a safe level where i dont have to worry about knock at all. i couldnt get it below 17-18 lbs with my hd actuator, so i switched over to the stock actuator. i was still having problems. to i lengthened the rod as long as i could, and you could actually hear the wasegate chattering againset the dp (the actuator rod was holding the wastegate open). the car still make about 13 psi of boost(it comes up kind of slow, but still steadily climbs)! so, i just tighten it enough so that it isnt chattering any more. the car is making 17 psi of boost again. Im confused. is it just time that i switch to an external style dp so that i can control boost better? thanks for any advice.
-my combo is in my sig
-jeff
-jeff
