boost HP ?
bad2bone
badtobonebuick.com
modifications and costs required to add 2nd turbo charger - currently have a TE44 model single
V6sleeper
What boost are you running? you may have what your looking for left in that turbo, i went real fast with a te44 years ago,
its a different turbo at 27# then it is at 18#
run it out it will feel like there's 2 of them
bad2bone
badtobonebuick.com
thanks for reply -- by the description of your car you are using alky to get 27# or?
V6sleeper
Yes i did, the te44 is long gone tho, but i did use alky to achieve 27 and even 30psi at one point with that turbo before it runs out of steam around 440 wheel hp..and note my care was tuned well.
dont run that high without a good tuner..
Mr.Spool
minor increases sought - I imagine the meth or alky system is way to go. Any input on modifications necessary for meth or alky over stock?
Rjc plate,tt alky chip 5.7,volts to your upgraded fuel pump,scanmaster,wideband o2,depending on power sought after upgraded injector,a 44 will nearly hit 600fwhp with an aggressive tune.i would aim for 26psi get afr where it needs to be and see how you like it.a built trans or shift kit is a must
NY Twin Turbo
All the good stuff.....Times 2.
I guess by your car description you run methanol. What modifications did you employ and what type of kit ?
Kit? Methanol or twin turbo?
My methanol set-up was custom tailored for my application. A standard Razor Alky kit is the one you would want to use. Call, tell Julio what mods you have in place, and he'll send you an off-the-shelf kit that you need.
Every one here is certainly bored with My twin turbo story. But I'll just say this.....it ain't no kit. And no "kit" will ever make it easy or cheap.....or worth it.
NY Twin Turbo
Quick question.
How come some of us call Julio's kit the "Razor" kit and others call it "Alkycontrol"?
I feel a little dumb for asking. Like I should know this.
